soarer260@hotmail.com 0 Report post Posted March 5, 2009 Hi guys, After searching for a few days I have not really found what my issue is here. Basically the electric seats and power mirrors work when they feel like it, some times not at all and sometimes straight away. Its like power gets cut to them at a certain point in time weather its parked up or your driving or at the traffic lights.... just seems to be totally random. However its extremely annoying. I thought one cause could be the seat switch but that does not seem plausible in this situation. My guess is a power loss of some sort? Like a relay sticking, or having bad contacts?? Any information / help / a solution to this would be excellent! This is an E34 540i 1993. Cheers Mike Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 5, 2009 do you have memory seats /mirrors? Quote Share this post Link to post Share on other sites
soarer260@hotmail.com 0 Report post Posted March 6, 2009 do you have memory seats /mirrors? I do indeed, is it to do with the control box under the seat? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 6, 2009 thhats my thoughts at the mo.i wonder if you can bypass it and have manual control only of seats and mirrors Quote Share this post Link to post Share on other sites
soarer260@hotmail.com 0 Report post Posted March 6, 2009 thhats my thoughts at the mo.i wonder if you can bypass it and have manual control only of seats and mirrors Yeah thats an idea, might be tricky but dont see why I couldnt just rewire it under their neatly so all the motors have a direct feed to the power cable. Then again, the mirrors might be the next issue with that... will look into it as I need to take the seat out to replace a motor tomorrow so will see what the go is. Might open up the box in that time and see if there are any components that could be replaced - old caps perhaps could be the culprit or bad relays? Quote Share this post Link to post Share on other sites
BM WORLD 1264 Report post Posted March 6, 2009 Yeah thats an idea, might be tricky but dont see why I couldnt just rewire it under their neatly so all the motors have a direct feed to the power cable. Then again, the mirrors might be the next issue with that... will look into it as I need to take the seat out to replace a motor tomorrow so will see what the go is. Might open up the box in that time and see if there are any components that could be replaced - old caps perhaps could be the culprit or bad relays? check fo rdry joints , bad conections in relays etc . i might have a replacement control box . depending on which type it is .cheers. also check the main power fuses under teh seat (green 32amp ones) the sockets often burn out . Quote Share this post Link to post Share on other sites
