BM WORLD 1291 Report post Posted March 16, 2009 (edited) http://www.trademe.co.nz/Browse/Listing.aspx?id=208366142 http://www.trademe.co.nz/Browse/Listing.aspx?id=208364324 http://www.trademe.co.nz/Trade-Me-Motors/C...n-208359145.htm will also be adding soon a full brake upgrade kit for a e28, e24 ,e34 etc . large 540i front and rear brake discs calipers etc excellent bolt on upgrade for e28 528i 535i , e24 635csi and some e34 525i 535i 530i etc fronts are 302mm by 28mm discs and bigger pistons calipers and about 20-30% more brake pad surface area rears are 300 by 20mm alos with bigger pistons and brake pad surface area , they work realy well , have same set up in my e28 . stops lap after lap from 200km/h plus around puke with no fade etc Edited March 16, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 16, 2009 also a 2.8l crank for upgrading you m50/m52 or m20 2.5l engine to a 2.8L . http://www.trademe.co.nz/Trade-Me-Motors/C...n-208392689.htm Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 16, 2009 whats the diff ratio Brent?Is it a big case or med case? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 16, 2009 whats the diff ratio Brent?Is it a big case or med case?didn't you look at the TM link .its a large case 2.93 ratio . what are you looking for?? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 16, 2009 didn't you look at the TM link . its a large case 2.93 ratio . what are you looking for?? did not look at TM link,sorry.wouldnt mind a slightly higher diff(ie lower numbers than the 3.64 i have)I think i have a med case though.Just curious really Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2009 did not look at TM link,sorry.wouldnt mind a slightly higher diff(ie lower numbers than the 3.64 i have)I think i have a med case though.Just curious reallyyours is a lsd i take it . then just get some 3.73 or 3.9 gears and swap them over , i can do a 3.91 e34 medium case diff , then just put your lsd pack into it Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted March 17, 2009 seeing as E30 M3's run E28 brakes, this kit would fit an M3 would it not? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2009 (edited) seeing as E30 M3's run E28 brakes, this kit would fit an M3 would it not?not sure if all the e30 m3 brake parts are the same as a e28 .will check parts etc i think calipers might be the same but discs have different top hats etc ?? ok .e28 rear calipers are the same as all e30 except m3 and all e28 except m5, but not the carrier or brake disc front brake carrier are common to e30 m3 and e28 535i etc some part ssame as e32 735i etc . maybe you can make them work with using some bits ?? not sure , welcome to try it out Edited March 17, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 17, 2009 yours is a lsd i take it . then just get some 3.73 or 3.9 gears and swap them over , i can do a 3.91 e34 medium case diff , then just put your lsd pack into it I think he wants to go the other way (longer ratio). How much for the 3.91? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2009 I think he wants to go the other way (longer ratio). How much for the 3.91? ok , sorry , i have some older e28 medium case diffs 3.25 and 3.46 , so you could take the gears out and fit to your diff Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 17, 2009 I'm keen on the 3.91 - how much for that? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 17, 2009 I'm keen on the 3.91 - how much for that?$180 for medium case 3.91 open from a e34021433600 cheers Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted March 23, 2009 last chance to get the 2.8L crank.... http://www.trademe.co.nz/Browse/Listing.aspx?id=208392689 Quote Share this post Link to post Share on other sites
