MattA 165 Report post Posted October 13, 2004 My speedo has just decided that it's not going to count k's anymore it still reading the speed just not clicking over anymore. Anyone had this problem or heard of it and any sugestions on fixing. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 13, 2004 Great!!! Now you can drive your vehicle as much as you want without addding k's to it!! But seriously, you will need to pull the instrument panel out and have a look if it is something there. It is an electronic panel, so if you are getting a speed reading, the signal is probably getting to the panel, so it is likely to be a prob in there. There is a thread in the FAQ section called SI Board that will tell you how to remove the panel. Good luck Quote Share this post Link to post Share on other sites
