viraaj1 0 Report post Posted March 19, 2009 Hi, Is there anyway that you can differentiate bmw E36 series 320i coupe engines ? From these engines M50B20 M52B20 M52B25 M50B25 Thanks Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted March 19, 2009 M50B20 M50TUB20 and M52B20 are the only 320i engines from and E36. The M50B20 doesn't have Vanos, the other two do. The M52 replaced the M50 in 1994. The M52TUB20 wasn't used in the E36's, only used in the early E46's and E39's before they upgraded to the M54 in 2001. Hope that helps. Quote Share this post Link to post Share on other sites
viraaj1 0 Report post Posted March 19, 2009 thanks is there any way to distinguish from vanos to non vanos ? Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 19, 2009 (edited) m52 have plastic valve covers (the one under the other plastic top cover). M52 are ali blocks . SS exhaust manifolds m50 cast iron , cast iron exhaust manifolds . different afm and inlet manifolds etc. also they will have model numbers cast into the block as well Edited March 19, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted March 20, 2009 M52 has the oil cap at the front, M50 has it at the rear by the firewall. And the VANOS is the bit that sticks out at the front of the valve cover. Quote Share this post Link to post Share on other sites
