melowpuf 19 Report post Posted March 23, 2009 (edited) Before I whack it on Tardme I will offer it out to Bimmersporters. Complete M50B25 Non Vanos Engine, 170,000ish K's on the dial. Was running in excellent condition before I removed it from the car. Was intending to use in a conversion but attention has been diverted elsewhere. Engine is there for $700 ono. If you want the full conversion (everything that came from the engine compartment, uncut wiring loom/AFM/ECU etc) I dont have the flywheel/gearbox/starter motor though, m20 flywheel/starter motor bolt on, gearbox with mount/gear shift modification. you can have the lot for $850. Can deliver in Auckland. Edited March 23, 2009 by melowpuf Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 23, 2009 Non-vanos out of a ??? A better question - does it have the right sump to fit an E30. Quote Share this post Link to post Share on other sites
melowpuf 19 Report post Posted March 23, 2009 Non-vanos out of a ??? A better question - does it have the right sump to fit an E30. Ah yes forgot that important bit. It is the right sump for you boys its from an E34. Quote Share this post Link to post Share on other sites
Mattzy 0 Report post Posted March 23, 2009 You've got a text Quote Share this post Link to post Share on other sites
rds 0 Report post Posted April 14, 2009 Can i take the lot for $800, and ill sort the shipping? Quote Share this post Link to post Share on other sites
melowpuf 19 Report post Posted April 14, 2009 PM'd Quote Share this post Link to post Share on other sites
rds 0 Report post Posted April 15, 2009 MINE! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 15, 2009 MINE! Good score.... let the fun begin Quote Share this post Link to post Share on other sites
