entscheidend 0 Report post Posted May 6, 2009 PCV Valve, intake gaskets, pipe installed. (old one had oil dripping out if it) Result - no difference in idle. still have "jerky" transmission changes for gears 1,2,3. Although it does accelerate alot quicker. MAF Air flow meter next? It cant be the O2 sensors - they would def. throw a code right? Actually the MAF hasnt thrown oone either. Glenn - any ideas? Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted May 6, 2009 Need to check it again for you... did we drive the car with the scanner hooked up and check live data last time you called in ?? Quote Share this post Link to post Share on other sites
