Carl 3 Report post Posted April 7, 2009 (edited) # (Amp) Description ============== 1. (7.5) Left high beam headlight(relay K3) 2. (7.5) Right high beam headlight(relay K3) 3. (15) Auxiliary fan, 91°C(relay K1) 4. (15) Turn/hazard indicators lights 5. (30) Wipe-wash, headlight cleaning and intensive cleaning systems(relay K10) 6. (7.5) Brake lights (15A if additional brake lights are fitted), automatic cruise control, map reading lights 7. (15) Horn(relay K2) 8. (30) Heated rear window 9. (15) Selector lever position indicator for automatic transmission 10. (7.5) Instruments, on-board computer, reversing lights, Service Indicator 11. (7.5) Fuel pump, fuel supply pump 12. (7.5) Radio, Check Control and instruments 13. (7.5) Left low beam headlight (relay K4) 14. (7.5) Right low beam headlight (relay K4) 15. (7.5) Rear fog lights (relay K4) 16. (15) Seat heating (relay K5) 17. (30) Sliding roof (relay K5) 18. (30) Auxiliary fan, 99°C (relay K6) 19. (7.5) Mirror control, mirror heating (relay K7) 20. (30) Heater blower, air conditioning (relay K7) 21. (7.5) Interior, glovebox and luggage compartment lights, torch, clock, radio memory, on-board computer 22. (7.5) Left side, rear and parking lights 23. (7.5) Right side, rear and parking lights, licence plate lights, instrument lighting 24. (15) Hazard warning flasher 25. (30) Not in use 26. (15) Touring: rear-window wipe-wash system 27. (30) Central locking system, door lock heating, on-board computer horn, Sound System 28. (30) Cigarette lighter, motor-driven radio aerial, independent fuel-burning heater 29. (7.5) Left fog light (relay K8) 30. (7.5) Right fog light (relay K9) Relays ===== K1 - Normal speed K2 - Horn K3 - High beam K4 - Low beam K5 - Unloader K6 - High speed K7 - Unloader K8 - Fog lights K9 - Fog lights K10. Wiper control Additional Relays ============ In front of the fusebox just on the forward part of the left strut is an additional little box that contains the master relay (white) and one or two fuel relays (orange). There are also two more relays behind the glovebox, one blue and one yellow, but someone else will have to shed light on these two. Edited January 26, 2010 by pando Quote Share this post Link to post Share on other sites
