BM WORLD 1296 Report post Posted April 7, 2009 just had some work done my 86 e28 M535i . now my ABS doesn't work . had new brake pads fitted front and rear , also replaced all the std rubber brake lines with stainless steel braided lines . brakes work orsome now ,. real tight brake pedal feel etc . but since picking up the car and after teh M-run drive last sunday my abs is not working , but no abs light has come up . have replaced the 2 relays in the abs pump , no difference , have sawpped the abs ecu box out with another , still no difference even when you unplug one of teh abs wheel sensors the warning light doesn't light up . not sure where else to look , there is no fuse for the abs in the fuse box that i can see . so did the blending of the brakes do something to pump?? or maybe when i picked it up drove home ,and when i got home the car didn't start because teh battery was flat so had to jump start it . maybe that has caused something ??? Quote Share this post Link to post Share on other sites
