tibbs.james 1 Report post Posted April 9, 2009 THAT !!! is a brand new Mahle Piston Ring. Popped it in the piston ring expander,aligned it all up. started to expand it, this was the first one too and it didn't feel normal. Then SNAP The others felt nice and springy as they expanded so hell if i know. Its not like i can take them back either. Uh Gutted, yes i know how to use a piston ring expander. So that's it, long weekend of engine building = fail Bank account next Tuesday is going to be $160 poorer. Quote Share this post Link to post Share on other sites
TDP 0 Report post Posted April 10, 2009 Rude buzz. No chance of picking one up tomorrow? I'm kinda hoping parts places are going to be open. Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted April 10, 2009 Deeped! Whos the supplier for them? Im pretty sure tommorow is a normal day for shops opening that are typically open on a normal weekend. Theres always things like this that rob your bank account as far as projects go aye, sux dude! Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted April 10, 2009 Have a drink mate Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted April 10, 2009 Talk nicely to the guy that supplied you the rings, and explain that you think it was faulty as the rest are Ok. If he's a half decent chap he would replace it and send the broken one back to the factory for testing. And if that doesn't get you anywhere, you can have a bit of a rant at them to make you feel better Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 11, 2009 Only I'm not sure where they came from or if i can get a hold of the invoice/receipt ( they were a present form a mate ) On the bright side, i would rather have a faulty ring on the bench rather than inside the engine. Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted April 11, 2009 I had the same thing happen to me with a 1600cc escort engine and they were MAHLE rings too. Atleast a set of rings was only $40 lol Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 13, 2009 Uh I have worked out what happened. It looks like as i was expanding the piston ring, the tool got all wonky- and of course myself having not used a ring expander very often more pressure plus twisting = boom. I tested this on an old piston ring and while it installed fine it felt similar to what it did when the other one broke. I have found a way to get my "individual" piston ring of the same brand through an engine shop. I have also successfully installed the other pistons-rings and bearings to very good results. However a bad experience has worked out alright in the end and i know for next time. and I have my engine block built up minus one piston. Quote Share this post Link to post Share on other sites
