Jamez
bmw not starting
K so done the engine swap
engine does not start
Symptoms are
  • ICV Hums like it should
  • all in car elec's work
  • nothing happen when key is turned onto full
  • no electricity to fuel pump
  • fuel pump really thing does not tick or make a noise
  • there is good grounding everywhere
  • Swapped ECU's and it made no difference
  • all fuse's and relays in the fuse box are operational
  • all plugs are in
had a sparky look at it and he was confused azzzzz
scenario is engine was going a few days ago and now has been swapped from a 325i to a 320i of the same year
hellllllllp please, I want to get it going for the Anzac cruise
p.s. its not the dizzy cap and rotor :P
Edited by Jamez
Check your wiring to the Starter, alternator and your engine earths.
Guest Simon*
sh*t James thank f**k for clearing that up! Was just gonna' suggest that.
Incidentally I had a puncture the other day - turned out it was the dizzy cap too
Seriously though, impressed at how fast you've cracked through your engine swap and stuff. Good luck getting the beast going :)
PROBLEM FIXED!!!
when doing a manual conversion make sure that you connect the 2 wires that stop you from turning the car on if not in park, I have since connected them up
now it works.......
