Jamez 2147483647 Report post Posted April 21, 2009 (edited) K so done the engine swap engine does not start Symptoms are ICV Hums like it should all in car elec's work nothing happen when key is turned onto full no electricity to fuel pump fuel pump really thing does not tick or make a noise there is good grounding everywhere Swapped ECU's and it made no difference all fuse's and relays in the fuse box are operational all plugs are in had a sparky look at it and he was confused azzzzz scenario is engine was going a few days ago and now has been swapped from a 325i to a 320i of the same year hellllllllp please, I want to get it going for the Anzac cruise p.s. its not the dizzy cap and rotor Edited April 21, 2009 by Jamez Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 21, 2009 Check your wiring to the Starter, alternator and your engine earths. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted April 21, 2009 p.s. its not the dizzy cap and rotor sh*t James thank f**k for clearing that up! Was just gonna' suggest that. Incidentally I had a puncture the other day - turned out it was the dizzy cap too Seriously though, impressed at how fast you've cracked through your engine swap and stuff. Good luck getting the beast going Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted April 21, 2009 This was a complete b*tch. Stumped everyone! Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted April 21, 2009 PROBLEM FIXED!!! when doing a manual conversion make sure that you connect the 2 wires that stop you from turning the car on if not in park, I have since connected them up now it works....... Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted April 21, 2009 common thing - inhibitor switch Good sh*t hows it running man? Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted April 21, 2009 Rofl, good job. :-) Quote Share this post Link to post Share on other sites
