entscheidend
My sunroof is stuck? I think
Ok, when I "one touch" the sunroof to open - she goes back all the way. But the is a crunching sound about 60mm from the front of the sunroof.
When I one touch it back - it gets stuck in this exact same position. I then have to manually close it and it is ok.
Thing is the right/rear of the SR (when closed) is a good 12mm lower than the left side/rear. Obviously an alignment issue here.
I took the allen tool out of the toolkit, took the sunroof/phone speaker panel off and stated to wind it back manually to re-align the roof. When I do this it makes the SR tilt up with the inner cover moving back as normal.
Is there a way of getting to the back of the sunroof to adjust those arms without taking the whole headliner off?
Or is it possible I have broken teeth in the tracks??
