petemcc 0 Report post Posted May 3, 2009 Hi My e38 740il has a reasonable oil leak that I noticed today. Haven't had a good look under it yet. Are oil leaks common on the m62 engine? If so where do they noramally leak? Also what do you guys suggest for a workshop manual? I see there are some you can get on trademe that are electronic and come with cords to hook your diagnostic port to your computer. Any good? Or should i just got for the old haynes manual? Cheers Pete Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 3, 2009 Yes oil leaks are common. From many areas. You need to clean off and recheck. Quote Share this post Link to post Share on other sites
