58rabbit 0 Report post Posted May 4, 2009 Hi thanks for all the replys about the noise but I have investigated properly and found that it is the idler pulley attached to the front of the alternator. the bearing is very noisey but I took it out of the car and bathed it in crc and it is no longer noisey. I will put a new one in of course but now that I know what it is there is no urgency. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 4, 2009 (edited) Hi thanks for all the replys about the noise but I have investigated properly and found that it is the idler pulley attached to the front of the alternator. the bearing is very noisey but I took it out of the car and bathed it in crc and it is no longer noisey. I will put a new one in of course but now that I know what it is there is no urgency. Yes there is urgency... they disintergrate if left on in a worn condition. You'll end up with a mess of belts, broken fan blade and possibly a damaged radiator. Edited May 5, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 5, 2009 If the bearing is designed to run with grease, CRC will do nothing but wash the grease out... Leading to a demo jobn of the bearing and whatever else it takes down with it. Best get it seen to. Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted May 6, 2009 If the bearing is designed to run with grease, CRC will do nothing but wash the grease out... Leading to a demo jobn of the bearing and whatever else it takes down with it. Best get it seen to. I have just replaced mine. For under a hundred bucks get a new one bang it in and forget. Absolutely worse case scenario, and something I would try to avoid like the plague, is to see if you can clean it out as good as you can, repack it with grease as well as you can, put the noisiest part of the pulley on the unstressed side when bangin it back in and pray. You might get away with it if the noise has just appeared, but if its been squealing like a stuck pig for several months chances are its haddit. But for the money it would be crazy. It is a beemer after all. Doing maintenance on a rangi budget will probably kick you later. Quote Share this post Link to post Share on other sites
58rabbit 0 Report post Posted May 6, 2009 Yeah I got a new one, is $111 expensive???, will chuck it in on the weekend. Quote Share this post Link to post Share on other sites
