ewie 0 Report post Posted May 14, 2009 You guy's have probably seen this on Trademe: http://www.trademe.co.nz/Browse/Listing.aspx?id=218178819 but will ti work on a "standard" E46? The speedo has a higher range and there's an oil temp guage where the economy guage is on the std version. Also, would the odometer swap from the existing cluster into this one?? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted May 14, 2009 straight from e46fanatics: http://forum.e46fanatics.com/showpost.php?...amp;postcount=1 Gauges/Instrument Cluster: Difficulty: ?/10 DIY: ? Part Number: INSTRUMENTS COMBINATION UNCODED MPH 62117837972 $504.43 This has not been successfully done yet. People have plugged these in, and here are the results: WORKS 100%: - MPH - RPM - OnBoard Computer Functions - Lights - Indicators - Engine Temp. - Gas Info DOES NOT WORK: - Oil Temp. Needle - RPM Warmup Lights - Little orange ODO Tamper Light comes on...which is bad This is a DIRECT PLUG AND PLAY, but will not work 100%. You be the judge... Safe Alternatives: - Bimmian M3-Style Gauges - UUC Whiteface Gauges - Silver Gauge Rings w/ Red Sharpie'd Needles Quote Share this post Link to post Share on other sites
ewie 0 Report post Posted May 14, 2009 DOES NOT WORK: - Oil Temp. Needle - RPM Warmup Lights - Little orange ODO Tamper Light comes on...which is bad Safe Alternatives: - Bimmian M3-Style Gauges - UUC Whiteface Gauges - Silver Gauge Rings w/ Red Sharpie'd Needles So best to steer clear then by the sounds of it.... cheers Quote Share this post Link to post Share on other sites
jordyboy2 0 Report post Posted May 14, 2009 I was looking at this myself, then found that on e46 fanatics Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 14, 2009 The IKE is the bridging point between the KBUS and IBUS. It holds a lot of car specific data that needs to be recoded into the vehicle. A lot of work need to be done to have it 'bedded' into your vehicle. Quote Share this post Link to post Share on other sites
