Guest FrantiC Report post Posted May 19, 2009 Anyone got a spare m20b20 pre F/L intake manifold liying around they don't want and would cut for me?? I need one like this : As you can see on the back side of the manifold there is an extra *3* nipples, i want that whole back bit cut. Then I could have it welded to my 325i intake mani. for the extra nipples.. Seems like an easy way to get the extra vacuum nipples I need. Or a cheap manifold would do and I'll cut it Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted May 19, 2009 Aren't those manifold cast? I.e a bitch ass to weld??! Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 19, 2009 I thought they were aluminum? Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted May 19, 2009 People do similar to Nissan cast manifolds all the time I gather they are tig welded normally Should be fine Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 19, 2009 u can buy vacuum line T peices for next to nothing Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 19, 2009 yeah but they are sh*t aren't they ? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 19, 2009 they will be as good if not better than the rubber vacuum lines Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted May 19, 2009 I have a 2.3l manifold, has lots of stock vacuum holes. But I'm in the 03 Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 19, 2009 i mean the whole 5 items sharing the same small vacuum signal, Where as directly from the manifold seems more spread out. Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted May 19, 2009 can do in auckland but can send it Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 19, 2009 i mean the whole 5 items sharing the same small vacuum signal, Where as directly from the manifold seems more spread out. shouldnt really matter as long as they are connected ok Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted May 19, 2009 can do in auckland but can send it How much ? Wuld you be able to cut like the whole rear section, like cut the #1 and #6 runners off and cut it flush between #2 and #5 (from the edge of the #1 and #6 where you cut them off). Dunno if that makes sense for you or not haha. I'll find a pic of a manifold for ya. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted May 19, 2009 Have a bare 320i pre-facelift intake manifold, 65$ including shipping in Nz will leave the chopping up to you though. email [email protected] if interested. pretty sure it has the extra vac nipples you need. Quote Share this post Link to post Share on other sites
