Boost Junky 1 Report post Posted May 20, 2009 Hey guys, have done some googling too find out as much as I can about placing my O2 sensor in the correct place on my downpipe. From what ive collected I should not place it on the bottom of the pipe as it will be more likely to collect moisture, also ive read 1ft back from the turbo? Obviously this will only affect my light throttle driving but will also play a big part on my tuner being able to get the car base tuned and idling right etc? Correct me if im wrong as im still learning the gst of these gadgets Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted May 20, 2009 (edited) All I know for a fact is you can't put it too close to the turbo, it'll burn to death, and you can't put it too near the end of the exhaust, but that really only applies if you have a really short exhaust (like goes out the side behind the front wheel). 20cm or so down from the first bend on the downpipe would be ideal on your forward top mount set up *PS would have told you on MSN but you aren't there Postcount +1 Edited May 20, 2009 by Incary Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 20, 2009 What does your tuner recommend ?? If he knows the set up your running, he should be able to point you in the right dirrection. Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted May 20, 2009 All I know for a fact is you can't put it too close to the turbo, it'll burn to death, and you can't put it too near the end of the exhaust, but that really only applies if you have a really short exhaust (like goes out the side behind the front wheel). 20cm or so down from the first bend on the downpipe would be ideal on your forward top mount set up *PS would have told you on MSN but you aren't there Postcount +1 Yea thats what I was aware of also Henry, so where your saying would be roughly 2-3ft from the turbo. I know they are good for upto 500 deg so that probably makes sense. Lol yea I was too cold to be on the computer any longer What does your tuner recommend ?? If he knows the set up your running, he should be able to point you in the right dirrection. Thats another good point Glenn I always forget to ask him which make the most sense.. hardest person to get hold of on the face of the earth though haha Thanks guys! Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted May 20, 2009 I knew you'd know a lot of what i typed All good, get it sorted and cane the thing around a track! Quote Share this post Link to post Share on other sites
chaosad 0 Report post Posted February 25, 2010 Ive always put them in the front pipe, between the engine and the firewall, at the top of the exhaust pipe. If you still have a cat make sure the sensor is upstream from it. Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted February 25, 2010 uh May 21 2009 Quote Share this post Link to post Share on other sites
chaosad 0 Report post Posted February 26, 2010 This thread was only the 17th one down from the top, never checked the date. I'm surprised it wasn't buried under all the tumbleweeds Quote Share this post Link to post Share on other sites
