entscheidend
increasing the idle
Glenn - do you have equipment to increase the idle?
The idle as you saw is 400RPM and 600RPM with AC. This is too low isnt it?
Can you reprogramme ECU to increase?
I don't want to be silly, but cant you tighten your throttle top screw?
Yes we can now with our new diagnostic equipment
No you cant
Does that fuddle the DME? Tightening the throttle screw I mean
It can up set the TPI switch and the throttle butterfly position
From memory... entscheidend's car is fly by wire (EML)
Edited by *Glenn*
