raymondt 1 Report post Posted May 27, 2009 My factory amp is playing up... There are 10 speakers in my stock e34... I am reluctant to get new amps and re-run the cables... Also wanted to put a mp3/ipod headunit in. So I've decided to do this: http://www.bimmernut.com/forum/showthread.php?t=41056 Still trying to figure out which wire is which atm Will post some pics later What do you guys think? Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted May 27, 2009 (edited) i have some factory amps from e36 and e34 , what type is it . does it have 2 large plugs that look the same or one large and one small etc .. another way i have done mods is by putting in after market amps in the boot and using all the original speaker wiring . just run a new set of rca cables to the back , and fit capacitors behind the tweeters and midranges to cut the bass out of them . 021433600 Edited May 27, 2009 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
raymondt 1 Report post Posted May 27, 2009 (edited) i have some factory amps from e36 . Thanks Brent but its too late my amp is the same as the same one in the link I posted above. I've already destroyed all the amp connectors, and took out the capacitors and coils from the original amp The built-in mosfet amp in my Sony ipod headunit should be better than the factory amp? Edited May 27, 2009 by raymondt Quote Share this post Link to post Share on other sites
