Driftit 2246 Report post Posted June 8, 2009 Hey guys. Just wondering if it is possible to use the factory E39 TV (non widescreen) in a car that did not come with the unit from factory. Not fussed on having TV stations. But is it possible to install the unit without changing the loom over? Changing the loom is a mission and prob not worth it. I have the Business dual tuner system with tape deck and DSP. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 8, 2009 (edited) Hey guys. Just wondering if it is possible to use the factory E39 TV (non widescreen) in a car that did not come with the unit from factory. Not fussed on having TV stations. But is it possible to install the unit without changing the loom over? Changing the loom is a mission and prob not worth it. I have the Business dual tuner system with tape deck and DSP. Yes, you can do this You need a retro-fit loom which connects into the existing loom. You'll need following parts: Retrofit instructions (PDF file, read before you start buying parts) Retrofit loom (with DSP) Screen Navigation computer OR TV tuner OR both (the TV tuner or the nav drive the screen, so you need one or the other) GPS antenna (if GPS being fitted) Radio module Brackets, screws, etc New CD changer trim cover New antenna amplifier if fitting a >2001/09 radio into a <2001/09 car Optional: Telephone/Bluetooth DSP amplifier, speakers, CD changer remain unchanged. Edited June 8, 2009 by jochen Quote Share this post Link to post Share on other sites
Driftit 2246 Report post Posted June 8, 2009 Cheers Jochen. Where can I obtain this retrofit pdf? I have all the parts including the loom from the car that the tv is from. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 8, 2009 Cheers Jochen. Where can I obtain this retrofit pdf? I have all the parts including the loom from the car that the tv is from. You have a PM Quote Share this post Link to post Share on other sites
