BM WORLD 1299 Report post Posted June 12, 2009 my mate is looking for a M20 getrag 260 manual gearbox from 325i 323e 525e with sensor pick up points or at least the castings on the front of the bellhousing so we can drill them out to fit . or might consider a box with out these , maybe we could convert it to a newer motronic system . its to go into a e28 525e . thanks 021433600 like in the picture attached Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 12, 2009 Hi Brent I have a M20 260 going dirt cheap, its the box which has the casting for the sensors but they are just not drilled. Box needs an input shaft bearing as it suffers the getrag rattle but otherwise its been in a car and going ok changes into every gear ok, dosn't crunch or anything shifting just feels a wee bit vauge. ( could be more than shifter bushings ) Not looking for much, make an offer. Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted June 12, 2009 Hi Brent I have a M20 260 going dirt cheap, its the box which has the casting for the sensors but they are just not drilled. Box needs an input shaft bearing as it suffers the getrag rattle but otherwise its been in a car and going ok changes into every gear ok, dosn't crunch or anything shifting just feels a wee bit vauge. ( could be more than shifter bushings ) Not looking for much, make an offer. thanks for thatI will pass on the details to my friend i see your in chch. any idea what sort of cost to fr8 and how much you want for it cheers brent Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted June 12, 2009 (edited) freight is around $80-90 inc GST Ray has just sent a box down to me from Auckland so i can give you an exact figure once they charge my credit card Oh yes $150 for the box was my thinking, much less for it than that it might be worth while myself keeping it laying about. Cheers James Edited June 12, 2009 by Jimmy Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted June 12, 2009 my mate is looking for a M20 getrag 260 manual gearbox from 325i 323e 525e with sensor pick up points or at least the castings on the front of the bellhousing so we can drill them out to fit . or might consider a box with out these , maybe we could convert it to a newer motronic system . its to go into a e28 525e . thanks 021433600 like in the picture attached brent,I do have a gearbox what like you said,if you have a 260 box without the sensor,i can swap for you. Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted June 12, 2009 freight is around $80-90 inc GST Ray has just sent a box down to me from Auckland so i can give you an exact figure once they charge my credit card Oh yes $150 for the box was my thinking, much less for it than that it might be worth while myself keeping it laying about. Cheers James brent,I do have a gearbox what like you said,if you have a 260 box without the sensor,i can swap for you. thanks guys will pass on the details sorry i dont or he doesn't have a box with out sensors . but if we come across one , will work something out . cheers Quote Share this post Link to post Share on other sites
