BM WORLD
mate looking for a M20 manual gearbox
my mate is looking for a M20 getrag 260 manual gearbox
from 325i 323e 525e with sensor pick up points or at least the castings on the front of the bellhousing so we can drill them out to fit .
or might consider a box with out these , maybe we could convert it to a newer motronic system .
its to go into a e28 525e .
thanks
021433600
like in the picture attached
Hi Brent
I have a M20 260 going dirt cheap, its the box which has the casting for the sensors but they are just not drilled.
Box needs an input shaft bearing as it suffers the getrag rattle but otherwise its been in a car and going ok changes into every gear ok, dosn't crunch or anything shifting just feels a wee bit vauge.
( could be more than shifter bushings )
Not looking for much, make an offer.
Hi Brent
thanks for that
I will pass on the details to my friend
i see your in chch.
any idea what sort of cost to fr8 and how much you want for it
cheers brent
freight is around $80-90 inc GST
Ray has just sent a box down to me from Auckland so i can give you an exact figure once they charge my credit card
Oh yes $150 for the box was my thinking, much less for it than that it might be worth while myself keeping it laying about.
James
Edited by Jimmy
thanks
021433600
brent,I do have a gearbox what like you said,if you have a 260 box without the sensor,i can swap for you.
James
thanks guys will pass on the details
sorry i dont or he doesn't have a box with out sensors . but if we come across one , will work something out .
cheers
