APT 198 Report post Posted June 12, 2009 Hey guys today i have lost all mty interior lighting eg. cluster heater window switches lightting jsut basically everything that is ment to go on when you put your headlamps on is now gone.. also now i can put my windows up and down. Can anyone pls help me ? Andrew Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 12, 2009 Which car is it for? Quote Share this post Link to post Share on other sites
APT 198 Report post Posted June 12, 2009 Which car is it for? Its for the e30 Sorry. Ive checked all the fuses and they seem ok, interior light bulbs dont seem to get any power hmmm.? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 12, 2009 Check all the earths for the speedo + lights under the dash, one break in the circuit and everything doesnt work, ask me how i know Quote Share this post Link to post Share on other sites
APT 198 Report post Posted June 12, 2009 Will Do, I think i may of shorted the circuit tho.. Was adding some more lights..Hope its not a big thing to fix Quote Share this post Link to post Share on other sites
APT 198 Report post Posted June 12, 2009 Windows work now just the cluster lights and panel lights that are around the headunit Quote Share this post Link to post Share on other sites
james0202 0 Report post Posted September 7, 2009 Windows work now just the cluster lights and panel lights that are around the headunit Did you get around to solving this problem? I have the exact same problem in my e36 Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted September 8, 2009 (edited) Hey guys today i have lost all mty interior lighting eg. cluster heater window switches lightting jsut basically everything that is ment to go on when you put your headlamps on is now gone.. also now i can put my windows up and down. Can anyone pls help me ? Andrew Assuming E30 325i 1989: Fuse 23 (7.5A) feeds the illumination and the right hand taillights. If taillights are OK but instrument cluster not working then fuse must be fine. Pin 1 on the Light Switch feeds all interior illumination Wire is Grey/Red. This same colour wire goes to every illuminated switch If you have lost illumination to ALL switches / Ashtray / Radio / Instrument Cluster then check the Light Switch carefully. measure for power on Pin 1. Will be there in Park and Headlights On. Replace switch if faulty. NOTE: the window switch illumination comes from the Window Switch power feed. So if the Windows work but the switch illumination doesn't, then suspect blown window switch bulbs. Or bad / corroded connections etc inside the switch Edited September 8, 2009 by jochen Quote Share this post Link to post Share on other sites
