Matty104
Help needed ASAP
so im trying to pull a body kit off but its been urethaned on around the top but also in the middle where i cant quite get to ,
Is there an easy way of getting it off?
The kit is glass , can i use a heat gun to make it a bit more tacky?, The paint isnt an issue as it will be getting resprayed,
Any tips or hints?
much appreciated
was about to use nylon but found some plastic packing tape that they use to strap boxes up, ( the hard fiber stuff) , ran it up and down like a saw and bam it cut through,
Who puts 11 spots of urithane under there and all around the outside ASWELL, that was only on one part about 600mm long, ahh well , im making progress now
