pureboiracer
e30 driveshaft differences.
Hey guys.
I need to replace my drive shaft in my pfl e30. i have been offered one out of a facelift e30.
It is correct in the sence that it is a 240 shaft and i have a 240 box. but i heard there is a difference with the hanger bearings or something? is this correct? and will it bolt in?
Cheers for any help
yeah facelifts use a different hanger bearing, You can get them pressed off and swapped tho to fix that prob tho, I recently had to do this and it only cost me 25$ to get done at the local driveshaft specialists.
You can swap the bearings over yourself if you have a few tools and mechanical skills. Or get someone to do it as suggested above. No biggie.
