tire
E30 crossmember question
Is there any reason why the gearbox crossmember from my manual, facelft, 318i couldn't be used with a 260 box to convert my pre-facelft 323i to manual? Like, are all the manual crossmembers the same across the e30 range?
Ta. Max
Have had both 4 and 6 cylinder manual cars, never noticed a differance between them!
I have a 318is one here thats aluminium and bolts to the body with 4 bolts (probably cause its aluminium).
With the sliding bolts in the chassis you'll probably be alright though.
