Nobimmer
EOI: Perspex/Poly sunroof panels
A mate of mine owns Acryform- a perspex mouldng company and is currently making up a dummy fit sunroof panel for my E30.
Just wondering if anyone else wants one, will get the pricing on Tuesday and will put pics up of fitment etc when I get it on.
He can obviously do all other parts out of perspex and polycarbonate.
Let me know if anyone's keen and can work something out.
Cheers
Ashkan
Just remembered, he was going to do one for Chris when he had ED1RTY, and that was with an adjusting sunroof, not glued in. Just needs new seal and walah-moon roof.
can he do side glass replacement for e46 coupe,does he need patterns or can i just buy perspex and cut myself? thanks
So the price for a 7mm Polycarbonate sunroof panel will be $311 delivered.
Will put pics up after he does mine to show you how good his work is.
Moe-Yes you can buy the plastic and cut it yourself, I'd imagine it would need a bend to fit properly though?
Otherwise he can thermomould them if you have another bit of glass.
Hmm. I'm looking at under 200 for a fi-glass cap to be made locally.. :)
Perspex would be awesome though!
^^its poly carb, different to your normal perspex you see in sub boxes etc.
It's lighter and doesn't smash/shatter so would be safer. Hence the price.
Also,the sunroof panel (apparently- just going by what I've been told) is bent on two apex's making it hard to bend.
Yeah it's double thickness. 2 layers of sheet metal. Quite a beast. I'll keep you in mind. Duct tape is doing a fine job at the moment ahaa.
Haha yeah ditto. Doesn't work too well after 100k's though.
Can just send you a piece of what I might be able to find left over if you wanna have a play with it.
