Ogg 0 Report post Posted July 6, 2009 Hi guys, I have an e30 and it appeared as if the driver side outer ball joint needed a replacement. I bought the part and then the trouble started... I built a homemade press : didn't work . Tried the hammer :didn't work. Tried both at the same time :didn't work. Now the car is at home in the garage with no real prospect of ever getting out . Any advice or help would be much appreciated. Thank You Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted July 6, 2009 replace the whole arm. or take your arm and balljoint to your local mechanic and get them to press it in for you Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted July 6, 2009 Yeah, Usually a second hand good arm with good ball joints does the trick, or a new arm if you like.. Quote Share this post Link to post Share on other sites
