Guest FrantiC Report post Posted July 15, 2009 FINAL piece to my e30 project.. As far as the engine setup goes. I need a hole cut for a ~38mm pipe I have to be welded to my stainless steel turbo manifold I have. I have been told I need to get it laser cut, so any recommendations in HASTINGS of a place that can do it for me cheap ? Anyone got hook ups? I would have attacked it with a grinder and made the hole myself cos I have mates who can weld, just no way of fitting a grinder disc in there, unless I want big chunks of manifold missing and holes in various pipes... Once this pipe is on the manifold I can get the wastegate on, get a dump back into exhaust made and other than getting it running good on 8psi, it should be ready for a cert.. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted July 15, 2009 Hole saw?? However you end up doing it, it'll probably need to be removed to access it and/or clean the shavings. Quote Share this post Link to post Share on other sites
