antony
Acentric rear trailing arm bushes.
Hey, I was just wondering about acentric rear trailing arm bushes.
Anyone on here used them, got information/links on them?
How much camber/toe correction do they give?
Thanks
Antony.
The series guys use them, and not much adjustment I believe.
There is adjustment available, but basically you use it to correct toe with lowered ride height. You will prefer correct toe over matching camber any day, provided that the cambers are not REALLY out.
I got mine to have toe OUT at static ride height, standard is toed in by about 1 degree/3mm each side.
Link
I was going to get the AKG ones. Went with the standard 75D ones though because according to previous buyers, they rotate out of adjustment often, and I wasn't going to be going low enough to cause a concern.
