piriaka 0 Report post Posted August 8, 2009 Hi My WOF failed cos the headlight lights settings are seized! Comment has included that they have to pull the light covers off but IF they bugger that up, I will be up for total replacement lights??? Can anyone tell me more about this issue?? Regards Ray Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 8, 2009 I can fix them for you. Take them out and send them to me Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted August 11, 2009 Hi My WOF failed cos the headlight lights settings are seized! Comment has included that they have to pull the light covers off but IF they bugger that up, I will be up for total replacement lights??? Can anyone tell me more about this issue?? Regards Ray It's just broken adjusters. Very common, easy to replace. You can buy replacement adjuster kits for <$50 I did mine. Be carefully fitting them - don't get the lenses dirty and don't break the headlight when disassembling. Plastic gets brittle with age, breaks easily... Tip: do both headlights at the same time. Quote Share this post Link to post Share on other sites
