Andre3000
ITB's for m20
What sorta work would you need to do to get these to work?
Obviously, delete AFM so the same computer as you are running already I'm assuming will work.
Anything else?
Anything else?
U just need to be able to run a MAP sensor, so any piggyback device that allows that would suit. (ie mapecu).
Nothing else is needed.
If you have them in a month or so after I pay for the cage I will take em. <_<
