WeteNZ 0 Report post Posted August 19, 2009 hi im new to this helpful site Ive got a e30 318 i got it with the trans buggered, it had the eh type 4hp22 so i seen a "regular" 4hp22 on trade me for $100 i was stoked so i got it. when i changed the gearbox i pulled the eh plug out from the left hand side and of course had no where to put the plug back into so i just left it hangin. my trans fluid hoses were differant so i hooked up an aftermarket trans oil cooler. the coolers all good. but i just cant seem to get the gears to change out of first, talked to the guy who i brought it off it worked in his bmw he took it out of. atf is topped up, i just noticed that my kick down cable on the throttle body doesnt retract. it actually stops the throttle from opening up about half the way and when theres no throttle the kick down cable is loose as if it helps the gearbox i brought was from a 320 e30 Can i use this gearbox in my 318 which use to have an eh trans, and what do i do with the eh plug(its just hangin out under the car lol) Any help is much appreciated guys thanks Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted August 20, 2009 get the correct trans . no other way unless you want to swap all the electronic inners from your old trans to the new one .(not even sure if its possible) Quote Share this post Link to post Share on other sites
Guest MAxx Report post Posted August 20, 2009 Err. If he has the completely mechanical gearbox with no electronic valve body then it should work fine. As long as its not the other way around having the gearbox with the electronic valve body and not the electrics in the car to go with it... Quote Share this post Link to post Share on other sites
WeteNZ 0 Report post Posted August 21, 2009 Err. If he has the completely mechanical gearbox with no electronic valve body then it should work fine. As long as its not the other way around having the gearbox with the electronic valve body and not the electrics in the car to go with it...exactly what i was thinking and hoping the answer would be thanks bro,i needed someone to understand what i was thinking thanks for your input Quote Share this post Link to post Share on other sites
