Shady
Got one of these lying around?
I Noticed this is broken. As per photo 1, it sits inside the drivers front wheel arch. 2nd photo is of it removed.
Mine is cracked, so I'm wanting one that is not cracked.
I'm also needing the plastic cover that goes under the front of the engine (photo 3) as its got a peice broken off as you can see in the photo.
Just wanting to replace broken & worn out bits of the car...I'm not going to add this to my WTB ad on Trademe or on here cause I dont know what they're called?
So if you got either of these 2 items, how much you want for them/it?
Would be good if you could include the clips & screws aswell thanks.
Cheers
Photo 1- Also, if you got the piece that you can see has 2 broken holes (its goes right around under the wheel arch) I'd be keen on that piece too.
Edited by Shady
