SUSPENSION
NEW SHIPMENT OF H&R SPRINGS SOON.
1 x 29664 BMW E30 6 cylinder 35mm-40mm $339.00.
1 x 29663 BMW E30 4 cylinder 35mm-40mm $339.00.
1 x 50406 BMW E30 6 cylinder 40mm-45mm $369.00 USA Spec spring kit lower and stiffer than Euro spec.
1 x 50404-88 BMW E30 NASA SPEC Racing springs. $450.00,2 inch lowering, can only be used with uprated shocks.
1 x E30 Swaybar Kit. 22mm fornt 3 x adjustable, 18mm rear 2 x adjustable. $1100.00.
1 x 29899 BMW E34 V8 35mm-40mm lowering $369.00.
1 x 29764-1 BMW E39 V8 535i/540i 30mm $419.00.
1 x 29255-2 BMW E60 5 series 35mm-40mm $439.00.
1 x 29534-2 BMW E24 6 series 35mm-45mm lowering $349.00.
1 x 29656-1 BMW E32 7 series 30mm-40mm lowering $349.00.
also in stock, X5 old and new model, and also new X6.
Plus springs for many other makes and models in stock, so if you have mates looking for springs, we also stock, honda, mitsubishi, audi, volkswagon, mazda, toyota, ford, kia, hyundai, holden, opel, vauxhall, chrysler + many more, possibly the largest variety of different spring applications available in NZ
If you would like a set or more info please call 021-378-902 for bank details to reserve your set, next shipment lands 7 weeks from now.
Cheers Keith.
Edited by SUSPENSION
We have a small amount of new springkits coming soon. 10TH October.
First in First served : )
3 x 29664 BMW E30 6 cylinder 35mm-40mm $349.00. (only 2 left).
2 x 29663 BMW E30 4 cylinder 35mm-40mm $349.00.
1 x E30 Cup Kit (suspension kit), 6 cylinder 51mm strut only. 35mm-40mm lowering springs with 4 x matched and shortened shock absorbers. $1200.00 (sold).
1 x 29899 BMW E34 V8 35mm-40mm lowering $399.00 (possibly Sold).
1 x 29672-1 BMW E34 525i-535i 6 cylinder 30mm-40mm lowering $399.00 (possibly sold Steven?).
Cheers Keith.
Keith, for E60 spring, will it be suitable for cars with Dynamic Drive and will it work with the standard suspension (non M-technik).
Also do I need to do anything else to wheel alignments etc.?
TIA
TIA
Designed to work with standard shocks, the ones we have are for 525d/530d/535d/540i/545i/550i, there are no notes about the dynamic drive so they must have tested them, we have done about 17 of these from memory with no issues, but if you are interested I can double check with H&R to be 100% sure :)
Cheers Keith.
LOL, mine is a 530i, which you didn't include in the list :-)
Will be good if you can check re Dynamic Drive. How far these springs will drop an E60? Also who's in Wellington can do the installation? TIA.
