alijanjan 3 Report post Posted September 12, 2009 Hi everyone I have just replaced the brake pads on my e38 (rear pads), and had replaced the fornt pads few months ago the check brake linings still stays on there had only been one sensor at front and one for the back when i replaced the pads and i used the old sensors. i was wonering if all four needed to be there in order to work properly or do i need new sensors evrytime the pads are replaced any help is much appreciated Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted September 13, 2009 Yep should only be 2 sensors, left front and right rear. Idealy you should replace the sensor every pad change, but I'm not sure if it's absolutely necessary to do so. My car didn't have any sensors at all when I last changed my pads Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 14, 2009 If the light comes on, the sensor is damaged = replace sensor. If you use aftermarket disc pads, the sensor may not fit correctly and break when you try and fit it Quote Share this post Link to post Share on other sites
alijanjan 3 Report post Posted September 14, 2009 If the light comes on, the sensor is damaged = replace sensor. If you use aftermarket disc pads, the sensor may not fit correctly and break when you try and fit it Thanks Glenn the pads are aftermrekt ought fom repco however the sensors fitted fine. so they may have been damaged. how much are the sensors each? Thanks Ali Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 14, 2009 About $40 each Quote Share this post Link to post Share on other sites
