User Name 19 Report post Posted September 27, 2009 Hi Guys Dont know the name as i forgot to take a pic its the Fuse on the Bottom Right - eg does Tach, Dash, few other things i have a alarm installed in the system - wired up my Tachometer and re-did my gauges - with everything pluged in and the dash off worked fine -- until i screwed dash etc back in now i keep blowing the fuse soon as i turn the ignition to ON and Disable my Alarm (uniden VS5000 Top model) - seems to do it also if i disable my alarm and dont turn ignition all i get on DASH is Battery light - Im thinking i knocked Ignition wire when putting steering cover back on. but if someone could let me know what Wires that fuse does as i figure the entire dash etc coming back off to trace all the wires. i did test removing all 2ndary wires eg. tach wire etc P.S this all eventuated after i removed the start reley from the car, still worked to i screwed everything up and then bang everytime went through 8 fuses - Thats Karma for you seen it worked and ran fine to i did everything up Quote Share this post Link to post Share on other sites
