amitch 0 Report post Posted October 3, 2009 I need a new strut bearing/mount assembly ( 2 I guess as I'll replace both) as the left one is clunking and the steering isn't self centering as well as it should. Are these available as after market or are they a BMW part only? Cheers Alex. Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted October 3, 2009 (edited) You sure its the strut mount and not something else? Like the shock itself or the lower outer ball joint ? If you are sure its the mount try http://www.bimmersport.co.nz/forums/index.php?showuser=1900 Edited October 3, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
amitch 0 Report post Posted October 3, 2009 You sure its the strut mount and not something else? Like the shock itself or the lower outer ball joint ? If you are sure its the mount try http://www.bimmersport.co.nz/forums/index.php?showuser=1900 HiPretty sure it's the mount. With the front off the ground, the mount appears to bind when you turn the wheel from lock to lock. The ball joint is new. Quote Share this post Link to post Share on other sites
