Deano 1 Report post Posted October 6, 2009 Can a 2 litre 80mm M20 block be bored out to standard size 83.98mm 2.5 litre? Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted October 7, 2009 Yup. But why not just start with a m20b25/m20b27 block? Save yourself the money boring it out that much.. You can bore m20 blocks to 86mm Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted October 7, 2009 Deano said: Can a 2 litre 80mm M20 block be bored out to standard size 83.98mm 2.5 litre? Want to buy my ETA block? just needs new rings and its good to go probably Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted October 7, 2009 FrantiC said: Yup. But why not just start with a m20b25/m20b27 block? Save yourself the money boring it out that much.. You can bore m20 blocks to 86mm Cause if you bore a 80mm to standard 83.98 you have basicly a new standard 2.5L block. I have a set of mint standard 11:1 eta pistons that I don't want to slap in an old block... Quote Share this post Link to post Share on other sites
