*Glenn* 856 Report post Posted October 8, 2009 (edited) Has anyone got an 18mm or 20mm rear sway bar for an E30 ?? BTW: I'm already running a 16mm bar that someone might want to buy as E30 325's run a 14.5mm bar Edited October 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted October 8, 2009 You won't find something that thick too easily. Will have to look here. and 325s run a 12mm rear bar. Convertibles and M325i's run the 14.5. Hope you like oversteering Quote Share this post Link to post Share on other sites
RyanG 0 Report post Posted October 8, 2009 How much do you want for the 16mm bar? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 8, 2009 (edited) You won't find something that thick too easily. Will have to look here. and 325s run a 12mm rear bar. Convertibles and M325i's run the 14.5. Hope you like oversteering Its not in a E30 thought. Its in the Ti ..I'm running Mtech 328 24mm front bar, actually it might be the 25.5mm bar. Ill need to check. Havent got the car at work today. Edited October 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 8, 2009 How much do you want for the 16mm bar? Will let you know once I can get a rear bar Quote Share this post Link to post Share on other sites
