Court M3
323i High idle after warmup
Been chasing a high idle for awhile on the car now. 83 323i At start up car idles high at 1000 rpm and steady, but once it warms up after around 5min of driving at idle it's around 2.5 to 3k RPMs. Question is could the time temp switch cause this problem. #`12 in the pic
http://www.realoem.com/bmw/showparts...55&...hg=11&fg=35
Or maybe a bad AFM?
It could be many things, air leaks, throttle body, TPS
Where are you ? ...put a location in your profile please
