Guest Simon*
Laptop repair - anyone?
Guest FrantiC
  Simon* said:
Yeah the absence of the PC beep kinda throws me. Isn't there enough flash memory on a mboard to hit bios even without any RAM installed?
It's a Dell XPS
There's like 20 bloody screws and lots of plastic to bend to get it all apart! Pisses me off :D
The memory is read only (unless you are flashing it). The BIOS needs to be loaded into the RAM.
Oh noes, Not a dell :ph34r:
Guest Simon*
LOL yes a Dell
OK so BIOS is on the RAM? No RAM no go?! Haha am gonna try RAM before I rip it apart.
Off to Hastings in 10 mins, listen out for the V8 :ph34r:
Guest FrantiC
  Simon* said:
LOL yes a Dell
Nah nah, RAM is on the chip on your board. But everything gets loaded into RAM for processing. So the BIOS gets loaded from it's chip into RAM.
Drive past EIT lol I am at EIT at the mo and in 10mins I'll be out at lunch.
Guest Simon*
OK that makes more sense. I thought too that dodgy RAM shouldn't stop the HDD light from coming on, but a dead or problem mboard would
Ah won't be goin' past EIT on the way sorry ;)
laptop motherboards are common failures...
it's due to the heat they are exposed to...
Simple things to try...
1) complete power down, unplug from mains, remove battery, wait 30 seconds try again...
2) boot with no hdd - any errors (check power light on laptop - sometime the bios beeps are actually power light flashes on some laptop)
3) download a prog called memtest (http://www.memtest.org/) it will test your ram out for you
4) you should have a cmos battery otherwise you would loose all your bios settings pull that and power down system as in 1
5) is the system fans running? Very common for the fans to die and cook the system. Espically if you use it on a soft surface as it blocks the intake vents... (stupid designers)
what model xps?
you can download the service manual to tell you step by step how to pull it apart properly
Guest Simon*
1. Done. No joy
2. ditto
3. Will have to try it in another machine I guess
4. OK - getting to it is a bitch!
5. Nope! I just checked and the bloody fan is not running. Scheiser!!
Guest Simon*
  DRTDVL said:
what model xps?
1210
Good idea! Got time to find me a link? ;)
Whilst in your in there with everything apart, make sure you take the time to clean the fans. I had so much dust in there it looked like it was a spongy filter thing !
dry compressed air can from tricky dicky or jaycar is golden for that job...
wouldn't hurt to get a can of circuit board cleaner and giving it a good spray also..
I can do it,
I did one last week
Try pulling a RAM stick (if it's got two) and just use one.
in some cases a machine won't post with dead RAM.
I vote motherboard. Had a Toshiba notebook with similar symptoms last week - wouldn't do anything and appeared to be HDD. Turned out to be a cooked motherboard.
As a side note, to reinstate your entire system (all data, O/S, passwords, settings etc) easily to another machine you can use ShadowProtect to take an image and then roll it back onto the new machine. We use it at work on mission critical servers and can literally rebuild a server on new hardware in minutes (basically as fast as the network or USB caddy can transfer data)... Think you can download a trial version for a month.
Edit: Course, the HDD has to be operable for it to work.... And you can do it on secondary, primary, and USB connected disks.
Edited by elmarco
Guest Simon*
After pulling it all apart and giving it a good clean it seems to be the motherboard at fault. No life, no fan = bugger
Guest Simon*
Anyone had any joy sourcing a motherboard from Dell outside warranty - or are they just a generic one?
don't bother... maybe look for a broken model on trademe... But good luck...
Typically if its out of warranty and it's a laptop it's time to strip it - sell the parts and buy a new one...
Download a program called EASEUS data recovery wizard. It works 9 times out 10 to recover lost data. No software will recover all of the files and some maybe corrupt as a result of this.
If you like i can send you the full version which allows you to recover all the files. The trial is sh*t as
Guest Simon*
I'm pretty confident that all the data on my hard drive is fine. It's the motherboard or chip that's sh*t itself
Will change thread title I guess
It's pretty easy once you've got a usb enclosure just to grab everything off, since you can't just put that drive into a new laptop and be done with it.
(unless it's 100% the same)
yes you can...
you just need to install the required drivers that are missing
  DRTDVL said:
yes you can...
last few times I had tried this, Completely different chip sets, it would blue screen on start up.. Yes It can be done, I just prefer to have a clean copy.
That sounds really really weird as cpu/chipset shouldn't impact the software os installation. I've taken a few laptop drives and run them as primary drives on other machines, even swapped out sbs installs to other newer boxes...
We have swapped hdd's from p3's to p4's to amd athlons to dual cores as it's got some lovely licensed software that they lost the serial key to and the company no longer exists... whooo fun times...
Typically new machine = fresh install of everything but you can't always do that...
I know win2k play that nicely nice with swapping boxes, but a repair install would typically fix that... meant you kept all your software as installed...
It's a bit easier to experiment in a corporate environment, oh how I would love to play.
I had some problems going from an NF2 to NF4, would constantly bluescreen recovery installs ftw, though I try not to do that.
But normally I'll do it the long tedious way when repairing someone's computer.
Becomes especially annoying when they want "everything" backed up. and they don't tell you where everything is.
Or you find they were storing important files in the directX folder.
