antil33t
E30 Swaybar Links @ Mounts
As per title, Anyone got any? (that's ment to be links & mounts... fail)
Going to go to the wrecker and autolign today and see if they have any.
Not sure on what part numbers. But it's a 12mm swaybar? (325i standard I think)
Ta.
Edited by antil33t
^ Michael just needs the links + the metal mounts, he has the rubber insert mounts and the bar (I only know this cause I sold him the bar).
Yep, was not 100% sure what parts I needed, thanks for clearing that up Nathan :)
Edited by antil33t
Right, Got some parts today...
the things with the bushings in them, bushings look fine enough to be re-used. and one of the bracket peices for the rear sub-frame.
Turns out all the parts I needed can be bought from the dealer for bugger all, only issue is theres two weeks wait from germany.
So, If anyone has the mounts that attach to the car body, and one peice for the bushing thing to the subframe
let me know :)
*yes I have nfi what these parts are called*
Cheers.
