Guest WAGON
engine fitting
Guest WAGON
would a 325 engine bolt into 320 mounts?
what about the gear box?
i have all the parts needed
Guest WAGON
oh ryan how much were you selling your whole car for?
i need alot of parts :)
does yours have eletric windows in the back or wind up?
i need your trim and seats also
what color?
Some 320 gearboxes will work with 325 engines depending on their age. 320, 323, 325 mounts are all the same.
they r pretty much the same engine dude, just the displacement is different ie: M20B20, M20B23 and M20B25
There are Getrag 240 and Getrag 260 boxes out there, ratios are slightly different
all the 325's are equiped with the Getrag 260
also some early 318's got ZF S5-16 box
Guest Andrew
and the heads are different - engine management is different etc etc.
