gjgregory 0 Report post Posted October 17, 2009 Hi all. I'm in the process of replacing all the control arms, bushings, etc, in my 740, starting with the rear. Have replaced both control arms but am stuck when it comes to removing the ball joint in the , which are completely stuffed (a bit of a surprise really because everything else is not too bad). I'm trying to find some stuff to make a tool, but does anyone have the bmw tool to remove them, or something similar? Would really like to borrow it for a day if possible. See Tool A in this link to see what I need: http://www.bimmerboard.com/forums/posts/50230 Thanks in advance! Gavin Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 17, 2009 Yes you do need special tools. If you dont do it correctly you can damage the alluminium carrier. We can do it for you... sorry I dont lend out our specialist tools Quote Share this post Link to post Share on other sites
gjgregory 0 Report post Posted October 18, 2009 Yes you do need special tools. If you dont do it correctly you can damage the alluminium carrier. We can do it for you... sorry I dont lend out our specialist tools Thanks Glenn, I'd have to put the car back together to get it to you. so that might not be an option at this stage, unless I remove the whole wheel carrier. I'm not far away so I'll see how I go. Cheers, Quote Share this post Link to post Share on other sites
gjgregory 0 Report post Posted October 19, 2009 Thanks Glenn, I'd have to put the car back together to get it to you. so that might not be an option at this stage, unless I remove the whole wheel carrier. I'm not far away so I'll see how I go. Cheers, Got it sorted. I managed to whip up a tool using stuff from Bunnings and it worked a treat. Quote Share this post Link to post Share on other sites
