goeyboy 0 Report post Posted October 19, 2009 hi,my 1990 535i engine cut out on me while driving & wont start have replaced crank angle censor but still no go,we have power 2 the coil but no spark.any advice would be most welcomed. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 19, 2009 ecu?? faulty dry joints on the main pcb or output transistor for the coil etc is there 12volts on both terminals on the coil . check the rotor , have had them fall apart some times (spark to the dizzy but non coming out to the ht leads) Quote Share this post Link to post Share on other sites
goeyboy 0 Report post Posted October 19, 2009 hi,my 1990 535i engine cut out on me while driving & wont start have replaced crank angle censor but still no go,we have power 2 the coil but no spark.any advice would be most welcomed.cheers 4 that i will check out. Quote Share this post Link to post Share on other sites
goeyboy 0 Report post Posted October 19, 2009 ecu?? faulty dry joints on the main pcb or output transistor for the coil etc is there 12volts on both terminals on the coil . check the rotor , have had them fall apart some times (spark to the dizzy but non coming out to the ht leads) cheers 4 that i will check -out. Quote Share this post Link to post Share on other sites
