s da 0 Report post Posted October 26, 2009 (edited) hey was wondering can a if m40 will bolt up to m20b20's auto-transmission. .... few questions...... if so... - can the auto flywheel & torque converter from the m20 be used on the m40? - m20's (auto) starter motor? -does m20 exhaust bolt to the m40 manifold? -will trans still mount in the same position bolted to the m40? - are the afm's the same? -......... anything else I should be asking!!!!!! this would be using the m40's 1.3 ecu & m40 radiator.... will try find out what year 320 is! cheers paul d 320 is a 91 model, cheers Edited October 26, 2009 by paul d Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 26, 2009 No, no, no, no, and no. And why would you? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 26, 2009 Silver Fox said: No, no, no, no, and no. And why would you? +1.. why would you ??? even though you cant Quote Share this post Link to post Share on other sites
s da 0 Report post Posted October 26, 2009 Silver Fox said: No, no, no, no, and no. And why would you?not for me man!!!! give power over economy anyday!!!! I'm selling an m40 on tm & got asked Quote Share this post Link to post Share on other sites
s da 0 Report post Posted October 26, 2009 Silver Fox said: No, no, no, no, and no. And why would you???so was that no no no no its not possible or no no no you would have to be a grandma to want to do it! ) Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 26, 2009 Most parts are different, so would not be possible. Quote Share this post Link to post Share on other sites
s da 0 Report post Posted October 26, 2009 Silver Fox said: Most parts are different, so would not be possible.hey cheers again!!! Quote Share this post Link to post Share on other sites
