Roshen 0 Report post Posted November 3, 2009 Hi all. Hoping someone could point me to the location of the amp. I have a 1997 e36 318ti. there are 2 rear speakers, 2 front in the kick pannel and 2 tweeters in the door cards. Have already replced the front speakers. I dont know if the head unit powers the speakers or if there is a factory amp. I'd like to replace the amp, or add an amp to the system, I have a 2ch Alpine V12 that will do the job. I dont want to rerun signal cable, prefer to use the existing cableing, thats why i'd like to work out if there is a factory amp... cheers Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted November 3, 2009 Open tailgate and look to your left Behind that panel (carpet) is the location for the amp. Bit hard to get panel off. There should be a little plastic bin under the panel. You should also find the wiring for the disc changer there as well. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted November 3, 2009 in the left rear C pillar behind boot carpet etc Quote Share this post Link to post Share on other sites
Roshen 0 Report post Posted November 4, 2009 hmm, had a look, no amp in there. Remove the CD changer bracket and took out the carpet, no sign of an amp, the signal cable runs toward the front of the car, so i guess its just powered by the head unit. anyway, saturday i'll be installing the amp and bluetooth unit, will just have to trace the signal cable and make a plan, then hopefully i'll have a working A2DP bluetooth driving the audio system. Quote Share this post Link to post Share on other sites
