Forrest 35 Report post Posted November 9, 2009 (edited) I want to make some ducts for my front brakes. Think roughly about 80mm diameter should be sufficent. Any of the racers/wannabe racers know where the best place is to get this? Really don't want to use that Supercheap sh*t again. Cheers, Nathan Edited November 9, 2009 by Forrest Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 9, 2009 i used pipe around 100mm diameter, the kind the has a steel spring jobby in the middle. think i have around 500 to 600mm left if you wanted it bro Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 9, 2009 (edited) ^ I was about to pm you Matt lol. I could be keen, where did you tax it from? This is the closest I have seen so far: http://www.drivenperformance.co.nz/scripts...?idproduct=1411 obviously x2 one for each side. Edited November 9, 2009 by Forrest Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 9, 2009 i just got some from work ay man, was the last bit we had, can probly get it from an engineering shop such as paykels ( if you have that dow there) or an industrial hose place. its basically the same as that stuff from driven performance but clear, and doesn't have the fancy ends. I left the factory hose in mine aswell just to hold the back side in place anjust hoocked the front end up to the kit. Quote Share this post Link to post Share on other sites
skidz 196 Report post Posted November 9, 2009 Road & Track in Lower Hutt has it in stock, will cut to the length you need. Have a look at mine if you like. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 9, 2009 ^ Sweet cheers Stephen. I remember it on your car now. What is the easiest way to mount it? Cable ties? Quote Share this post Link to post Share on other sites
skidz 196 Report post Posted November 9, 2009 ^ Sweet cheers Stephen. I remember it on your car now. What is the easiest way to mount it? Cable ties? Easier to show you rather than describe. If you come around tonight as I am about to put the front kit back on. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted November 10, 2009 (edited) Bam. Zipties for the win. Brake ducts work so well.. No more flames though! :( :( :( Seem to have connected all the zip ties together in my pic.. The closest 2 are seperate. The back 2 are ziptied up to a braket on the frame rail. Edited November 10, 2009 by Incary Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted November 10, 2009 zip plumbing sell it, the same place you got that stuff for your cold air box from, ive got some here, i used it for my airbox Quote Share this post Link to post Share on other sites
