thorburn 123 Report post Posted November 13, 2009 (edited) do the rear springs fit? also do m3 struts bolt up to non-m steering knuckles? Will the weight of the 328 result in the car being noticeably higher all around? Edited November 13, 2009 by e46_323i Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 13, 2009 I was planning on using H&R springs built for an m3. Hopefully it should give it a slight drop and increase the spring rate a bit over standard. This will be going on bilstein shocks on the front. Would anyone recommend i give it a go or is this a bad idea? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 16, 2009 So will an m3 strut bolt onto a 328 steering knuckle or will this need to be modified? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 16, 2009 mixed words up. thanks for all your help 3pedals Quote Share this post Link to post Share on other sites
